1L243
Jan 11, 2016Explorer II
I added two outlets to the dinette. There was no access to a outlet nearby but Keystone made it easy buy cutting huge holes in the walls for wire access. I tapped into the GFI protected outlet for the TV.
Access for running Romex made by removing the radio head unit which was directly below the TV outlet. So I could run the wire and install a outlet to plug into..
14/2 extention cord wired into outlet junction box
Outlets installed in dinette
Ideally dropping the underbelly and running Romex into the bottom of the slide would have been the ideal way but way more work than I wanted to get into.
This will work for me, I just have to remember to unplug before retracting the slide!
Now I got to go out and clean the trailer before my wife sees it...
