- mkirschNomad II
NJRVer wrote:
JRscooby wrote:
What is better? A car with padded bumpers, or a car with a driver or other avoidance system that does not hit pedestrians?
Or what's better a car that has an angular bumper that would tend to flip you up and over or a flat "wall that would knock you down and then run over you?
Regardless, if you're the pedestrian you're not getting away without at least some broken knees... - JRscoobyExplorer II
NJRVer wrote:
Bedlam wrote:
Physically larger engines need physically larger hoods to cover them?
Well, in line 6 needs more hood length.
Well, starting in the mid '60s some model/engine combinations where getting tight to work on. (One Saturday morning I drove a station wagon to brothers body shop. Had key to feed watchdogs. I pulled a barely running El-Camino in, removed the engine. Hooked a chain to both trailer hitches to lead Ellie out and up the hill. Backed the little trailer in to load old engine, parked it out of the way. Pulled wagon in, lifted engine out, pushed wagon out, and down the street. Rolled Ellie in, bolted good engine in place. Not in a hurry, taking time for a couple of joints and beers, less than 4 hours, shop cleaned up, towing the old engine to car wash to start rebuild. I did haul the hood in bed to a friend, need more than 2 hands to put it back on.) By the mid '70s, changing the plugs on most took many wrench changes. Now, even a V6 can be a PITA. - NJRVerExplorer
Or what's better a car that has an angular bumper that would tend to flip you up and over or a flat "wall that would knock you down and then run over you? - NJRVerExplorer
Well, in line 6 needs more hood length. - JRscoobyExplorer IIWhat is better? A car with padded bumpers, or a car with a driver or other avoidance system that does not hit pedestrians?
- mich800Explorer
Bedlam wrote:
8.1 Van wrote:
cybertruck on 405 s FW, Dec 7th at 11pm. Ford F-150 move out the way. Elon Musk driving.
Pedestrian safety may be an issue with the Cybertruck design whether Musk is driving or someone else. Europe mandates certain designs that help protect a pedestrian when hit:
https://usa.streetsblog.org/2017/12/07/while-other-countries-mandate-safer-car-designs-for-pedestrians-america-does-nothing/
But many automakers design with pedestrians in mind even without it:
https://en.wikipedia.org/wiki/Pedestrian_safety_through_vehicle_design
Pedestrians should be afraid no matter what Elon is driving. He doesn't look like the most skilled driver. He completely took out the parking sign leaving the restaurant in the truck. - BedlamModeratorPhysically larger engines need physically larger hoods to cover them?
- NJRVerExplorer
Grit dog wrote:
NJRVer wrote:
Lynnmor wrote:
NJRVer wrote:
When you look vehicles today compared with what was on the market in the '60's and 70's, todays vehicles are huge.
Growing up we used to think of a Pontiac Bonneville as an absolute monstrosity.
Now park one next to Lexus and the Pontiac looks small in comparison.
:h The Bonneville was 7 inches longer and 7 inches wider with a foot longer wheelbase and an engine more than twice the size.
Hardly amounts to much difference 7" longer.
Engine size has nothing to do with it.
A lot of todays vehicles can't fit in a garage from the '60's or 70's.
Give it up bud. The big boats of the 50s, 60s, 70s-90s are every bit as big or bigger physically than today’s big cars. And most of the engines were bigger too.
Not sure what you’re getting it.
https://www.youtube.com/watch?v=1_ptUrQOMPs
Not sure why you keep referring to engine size.
Those old engines were giant boat anchors when you compare their size and weight to HP out put. - 8_1_VanExplorer
While Other Countries Mandate Safer Car Designs for Pedestrians, America Does Nothing
Maybe ban delivery vehicles and use solar powered trikes.
Solar-powered cargo trikes offer clean 'last mile' food transport in Amsterdam - BedlamModerator
8.1 Van wrote:
So the Cybertruck is worse for pedestrians than Sprinter vans and pickups ? How ?
If you read the links I provided early, you would have your answer. You probably missed this link too:
https://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29wgs/wp29gen/wp29registry/ECE-TRANS-180a9app1e.pdf
44,029 PostsLatest Activity: Jan 28, 2025
