Cummins12V98 wrote:
fj12ryder wrote:
Cummins12V98 wrote:
Bionic Man wrote:
It settles 2 1/4” with the RV on the truck. It is enough that some oncoming drivers were flashing their lights. Would have got the air suspension if I ordered the truck.
Bigger tires are for aesthetics. They won’t be huge but I’ve never been a fan of stock size.
You want the truck to set "LEVEL" and ride on the overloads. Yes I get flashed at times but oh well! I set 55" top rear bed to ground with factory rear air. LOVE it!!!
If the truck is down on the overloads it's going to ride pretty rough. I put bags on my old truck because it set down on the overloads, and rode like a lumber wagon. Got it off the overloads and it was fine. JME of course.
But FWIW, it looks like it's sitting a bit low in the rear. The truck that is.
100% disagree! Loaded you want the truck on the overloads that is what they are there for. They stop a lot of bouncing.
Pic could be deceiving. I highly doubt the truck is setting low rear with at the most 2,400# pin weight.
How does your truck sit when loaded? With the air suspension I’d assume that it sits at the same level as empty.
I’ve had 4 vehicles with OEM air suspension, and they all sat at the same level wether loaded or empty. That’s why I will go to airbags.
And the photo is not deceiving. I measured it. The truck settles 2 1/4” with the trailer on it.
I appreciate the comments about aligning the headlights but doing that would be a compromise for visibility of loaded vs unloaded. And it doesn’t change the way it looks.
Apparently some like the saggy look. I don’t.
