sapperb
Mar 29, 2023Explorer
opnspaces wrote:sapperb wrote:
Ok good evening, everyone. I was able to do some more research on it today. Ok I plugged it into a non-GFI outlet I flipped up all the breakers in the camper. Everything worked for about 30 seconds, then I heard a click, and everything went off. It never threw a breaker in the camper; it threw the breaker in my main fuse panel in my house (where it was plugged into). So, I flipped down all the breakers in the camper and hit the breaker back on in my house. So now I went and turned on the breakers in the camper one by one and it clicked again when I flipped up the breaker to the converter. So would this mean my converter is bad and causing this? I have to accept the fact that this converter may be as old as the camper, 22 years old. The converter should be located in the fuse panel of the camper? Again thank you everyone who is helping me.
Bruce
Most likely the converter, or it could be the charger. Many times they are in the same box but separate. It could also be something else on the same circuit. Unplug all electricity, take a photo of the fuse locations and pull all the fuses. Then see if you can open the front of the converter/charger. If so undo the wires from the breaker to the charger only. Now put the fuses back in and carefully plug in shore power, flip on the offending breaker and see what happens. If no tripping you have a bad charger. If it trips there is a short in the breaker panel or some other device like the microwave or whatever is also on that same circuit.
Here are some pictures
44,072 PostsLatest Activity: Aug 23, 2026
