StirCrazy
Mar 30, 2023Moderator
by the looks of that old converter, you should be thinking of upgrading it anyways and if it is causing issues its a good time to do it. THIS one is a direct swap for just the converter section. If you want to do what I did you could get a whole new power centre and get the modern filtered DC and such but they are not always the same size as the old Magnetek and you pretty much have to rewire everything. you could look at the PD4645, or PD4655 depending if you want a bit higher output for charging or not.
Steve
Steve
44,072 PostsLatest Activity: Aug 23, 2026
