sapperb
Apr 11, 2023Explorer
StirCrazy wrote:sapperb wrote:
Stircrazy,
Ok you wrote, "ya that might work, won't have any 12V power aside from what the battery will do itself so keep in mind depending how your battery is you 12V may or may not work of sort of work.". My 12V is practically brand new. So? see if it all works after I disconnect the converter/charger breaker, and don't use shore power to test it? Sorry for the dumb question, I don't know anything about this, but you guys are good mentors..
Bruce
once you turn off your converter breaker all you will have is what your battery will supply on its own and your 120v shore power, so I was just more or less letting you know to watch your battery isn't in a low state and if it is either charge it or don't use 12V power much while you're playing with the 120V. You're going to have to use 120 to test it otherwise how will you know if that's your problem?
When you have been trying to find the issue, does your shore power trip as soon as you turn it on? If so, I would turn the converter breaker off before you turn the show power on.
Oh wow! Thank you. I have a 4 day weekend this weekend. I plan on doing all that you all recommended. Thanks you.
Bruce
44,072 PostsLatest Activity: Aug 23, 2026
