RoyB wrote:
SOUNDGUY - They sure make it hard sometimes huh...
There's always a way to get around these problems
In the OP's case, yes it's apparent the manufacturer hasn't allowed for the possibility of dual batteries on the tongue. Many newer trailer models with a molded front cap also suffer in this regard. In my own case I was the one that created my own problem when I relocated my propane tanks from just aft of the tongue jack where the manufacturer had mounted them ...
... to the rear of the A frame as I have them now ...
As originally configured I could have easily mounted dual batteries, with my current setup I can accommodate just one 12 volt battery just in front of the tanks. With a custom box I might just be able to replace that G27 with a pair of 6 volt GC-2s but after thinking about it for awhile I think my preference now is to simply leave the G27 where it is and install a pair of AGMS - either G31s or GC-2s - in the front pass through storage compartment and switch between the two with a
Blue Sea m-Series 4-position Battery Switch.
