SweetLou wrote:
ACZL wrote:
Have your neighbor try Hot Shot Secret Stiction remover at next oil change. Then oil change after that, add HSS FR3. If by chance he's already changed his oil and won't be doing so again anytime soon, then add Motorkote Hyper lubricant to his oil now. Report back when you can w/ updates.
I am curious if you have tried any of these products you are recommending. I am always skeptical about putting additives into my very expensive engine which is in a very expensive truck. If so, what were your results?
Yes I have. They were developed for use for semis. The HSS stiction eliminator was orig developed to help w/ Navistars&Fords problem with the injectors on the 6.0 Powerstroke. It will work in all diesels. If 1st time, upon start up/shortly thereafter, you'll see a lot of white smoke from exhaust. This is caused by the HSS doing it's thing on cleaning out the injectors. Won't last terribly wrong. What happens is oil gets "baked" onto tips of inj thus causing what we would think is bad inj. when in actuality the inj is fine, just has the oil baked on it. The HSS will clean it off (white smoke) and save having to replace the inj.
Motorkote is a friction fighter. It uses whatever it's put in with as a carrier agent and adheres to metal surfaces, thus reducing friction/heat. MK can be used in engine oil, transmission oil, power steering/hydraulic oils. If you have a say a noisey engine, can pour MK into oil fill tube while running and the noise will go away. What the main goal is of MK is to reduce friction and heat thus translating into lower operating temps, better performance, better mpgs and HP along w/ reduced wear and tear. Yes I have used it and it does work. Many swear by a similar product in a white bottle, but this stuff is better.
I have also used HSS FR3 as a friction fighter in engine and like MK, it does what it says it will do. HSS Stiction eliminator tho is what I would use over MK Stiction Eliminator. Both HSS & MK products are aimed at the semi use, but are expanding the use into gas motors---just read product info/label to make sure it's ok to use. as some diesel products are NOT for use in gas engines. Example: MK has a product marketed for gas motors to help clean out Cat converters.
In the end, these are the only 2 product lines I would use or recommend for use in gas/diesel engines. May not be cheap, but they do work. Sadly, I cannot convince my company to try them. They would rather spend $$$ on repairs.
