I have a new Winnebago Micro Minnie and the toilet seat makes a lot of cracking sounds when you set on it, anyone had this problem and is there a solution.
The Dometic 310 has the same dimensions and mounting hardware as the 300 so it is all plug & play and easy to do. It took me less than 30 minutes to swap. Both come in standard and low profile height so, if you switch, make sure you get the same height type unless you want something different.
