Yamafan1
Sep 26, 2014Explorer
Fuses are good and clips are good. I pulled the board and used my multimeter to check continuity across the solder pins. The only thing I couldn't get a reading on was the varistor. That's the circle looking component that is used to cushin an electrical surge. AC power coming from the wall outlet is good and I even plugged a few things into it to make sure. I'm going to have to go with bad board on this one. It will run me about 138.00. Sucks because the trouble code it is flashing says it should be an AC heater failure. Maybe the solder pins for the ac heater are bad. Thanks for the quick response.
44,071 PostsLatest Activity: Aug 16, 2026
