Old-Biscuit
Sep 26, 2014Explorer III
You stated "on green light flashes 3 times every 10 seconds".
I took that to mean 1 time every 3 seconds
Now you are saying "the trouble code it is flashing says it should be an AC heater failure".
That code would be 'ON LED flashes 3 times every 3 seconds'
Unplug AC heater...plug the end of leads directly into a 110V AC source and force run it on AC heater.
Check next day if it is cooling.......if it is---power board issue
If it isn't----AC heater issue
44,071 PostsLatest Activity: Aug 16, 2026
