covered_wagon
Sep 14, 2019Explorer
Things I've done to mine, may be of some value to you
insulated the floor between basement and cabin.
Added 12 volt recepticle to cab over area
Insulated outside shower
Insulated behind the tail lights
changed noisy bath fan to a muffin fan.
Changed noisy range hood fan to muffin fan.
Changed toilet paper hanger to marine so no more unrolling by
itself.
Added Blue Sea volt gauge
Added support to the drawer guides
Changed the water fill door outside to higher quality door.
Mounted water pump on back wall with flexible pressure approved line on the
inlet and outlet to kill noise.
Added backsplash to kitchen counters.
Added actual sewer storage tube in rear overhang so when gaining access to the fitting it is right next to the sewer outlet. Drilled holes in tube to help rinse and drain.
Changed sink strainers to stainless strainers
Made access door to the cab over step for more storage under step.
Added bicycle cable to Generator handle cabled and locked to boat hook and thru bolted inside gen box side.
itself.
44,071 PostsLatest Activity: Aug 30, 2026
