burningman
Sep 14, 2019Explorer II
Added on/off switch for Happijack control unit. There are reports of it randomly activating a jack and toppling the camper. Seems it should have an on/off anyway.
The HappiJacs are unreliable failure-prone junk. I’ll be removing them soon and converting.
Added a wedge shaped piece on floor just inside the basement access door, so the tray doesn’t beat up the door flange when you pull it out.
Stuck little rubber bumpers on the folding step so it doesn’t scratch the bumper all up.
Glued dimes under where the set screws go to hold the extra rear step, so they don’t gouge out the aluminum.
Added Froli adjustable mattress spring setup, to allow air circulation below the mattress and prevent condensation and potentially mold. It’s also more comfy. The factory Hypervent they started including isn’t nearly as good.
I’m gonna upgrade the outside shower with a removeable, quick disconnect hose and sprayer.
