Siletzspey
Dec 06, 2019Explorer
Kayteg1 wrote:
... the system will keep cycling automatic breaker.
Hi Kayteg. Do you have just the 7-pin outlet, or did you add a separate high-current line (2/0ga)? Is the breaker you speak of associated with the 7-pin line, or high-current line, or the converter?
If your jacks are tied directly to the batteries, I would expect the batteries would take most of the load, and you shouldn't be blowing any charging fuses.
Where I'm still under-informed is how motors and inverters can demand a current spike when first turned on, and I believe motors can generate a spike when turned off.
--SiletzSpey
44,056 PostsLatest Activity: Jan 19, 2026
