okan-star
Dec 22, 2020Explorer
I can see it as an involved project , and I`m sure the sticking point for me would probably be the cost of the Reico T product ( no idea of the cost )
Reasons I can see for it being difficult = roof is foam core and has limited structural points to attach to
The lifts appear to need a hole to collapse into , location of water heater .... may be in the way
The lifts need to be inboard of the roof to allow the soft side material to be able to collapse
On a fairly new camper it is probably questionable
The good is Northstars are still inexpensive compared to some others
and they appear to have the lift included
Palomino appears to be the reason Reico came up with it
https://www.truckcampermagazine.com/news/rieco-titan-on-palomino-rv-s-new-lift-system/
I know in about 2007 Outfitter was putting a motor on the Heco
dont know what they do now , but the did retro fits then , maybe Hallmark also
You may want try to make a new crank and see if it does enough to allow you to use the camper
With my Outfitter I used a hand crank handle from a happi jac and put the spline- gear from the Heco on it that way you have more leverage ( dont remember how it was in 05 ) you could get one of the newer harder material gear cranks ito do it with . read this
https://www.hannarv.com/P/21252/HECOTruckCamperCrankHandle
