okan-star
Dec 23, 2020Explorer
Thats what I said I used to do also ,push up on the roof the first few inches when the arms connecting to the Heco rack are at the most horizontal . The camper that was the worst was the Outfitter 9.5 Apex with a polar cub on the roof and upper cabinets . I called Heco and was told at the time that was beyond their systems weight limits , I used to keep a bag of Heco parts in the camper to repair on the road .
When I sold the camper it went back to Outfitter to do a elec lift that they had just come up with
To the OP , maybe call Outfitter or Hallmark and see if they could sell you the parts to do this . As I recall because prior to selling I was going to do this ,its a gear reduced motor so it takes about a minute to raise the roof , and switches to stop the travel.
I could also see a way to build a small manual gear reduction box using the gear off a crank , attaching a larger gear infront of it and a smaller one to the side , with a nut on the front of it , to use a crank on it , all inside a slim enclosure
To bad manufacturers exceeded the limits of the Heco system before thinking this through , although I have to say the Northstar ts1000 I had after the Outfitter and the NS tc800 I had before it worked well , as the AC was in the wall not on the roof
