RickW
Dec 23, 2020Explorer III
Suggest trying one or two ceiling brace/cargo bars to help raise the top for the first foot or so. One type uses a pistol grip you squeeze to extend the top foot. (see 2 in 1 support/cargo bar at that freight store down by the harbor)
Put a large "foot" of thin plywood on the top foot to spread the force, or attach a pad on the ceiling at the best lift spot(s). As said above, once you get about 1/3 the way up, it is much easier to finish cranking.
I would also look at the hydraulic lifts used on 4 wheel campers to see if that is a retrofit possibility for you.
Note there are many more solutions using levers, hydraulics, bladders or extension poles. You just need to discover which is best.
Hope this helps,
Hope this helps,
