Steve_in_29
Nov 16, 2015Explorer
wvabeer wrote:
If your buying the 150 hopefully its a 4x4 for good mileage and not hauling the camper a lot I'd say get a set of 3000 lb wheels,LT E rated tires and air bags, go for it. But if your going to use the truck camper a lot I'd go for the heavier truck, a 250 has the same drive line as the 1 ton but sits lower.
Not quite, the F250 has a lower rated rear axle then the F350SRW does...6290lbs vs 7180lbs.
