DWeikert
Oct 04, 2013Explorer II
If you're planning to order new from the factory, don't hesitate to call Rex or Rory at Northstar to ask about modifications. My Adventurer normally only has a single propane tank. When I asked Rex if they could build me one that has dual tanks the reply was "No problem" without a moment's hesitation. I also had them mount dual type 31 AGM batteries next to the fresh water tank instead of in an outside accessible compartment. This brought the weight/CG lower and forward. Though if you went with conventional wet cells it would make maintenance more difficult.
