Mello_Mike
Oct 04, 2013Explorer
d3500ram wrote:
I am not sure of the default factory set-up for the Arrow. As DWeikert mentioned, Northstar can and does design and build to customer needs.
I will say this: I had a late 90's Arrow made for an 8' bed (no side saddles at the rear)... it had only 1 battery slot. My current Arrow which is designed for a short bed (permanent side saddles) has the slide out tray which houses 2 batteries.
That's good to know. Where is your battery compartment located? Do you happen to have a pic or two you can post of it?
