kerrlakeRoo
Jun 02, 2018Explorer
Instead of CW's "calculator", check the door pillar of your truck for the actual numbers. CW has no way of knowing if your unit received a HD or towing package unless they ran the vin or verified at the pillar. Their number could be right, but why guess, you have the info.
Also, not knocking Nash as a brand, but they are one of the heavier brands out there.
If something as small as a 17 is what you want explore some other lines, there are plenty out there in the >20' range which will weigh less, and be much cheaper. They may not all match the quality, (some will be close) but the quality doesnt matter, if you cant take it where you want to go.
