Vapor_Trails's avatar
Vapor_Trails
Not the typical Gas vs Diesel, ½ ton vs HD question
TLDR: 11,000-12,000lb bumper pull toy hauler. Need recommendations for a new truck to replace the ½ ton I currently have.
Want the details? Read on.
My situation is a little unique and I’ve been around for a while. I know how to use the search feature.
October 2017, got rid of our 2006 diesel pusher. We bought it used and enjoyed it for a few years but it was too much for us. We missed a truck & trailer setup.
December 2017, bought a 2018 Forest River WILDWOOD X-LITE T263BHX and a 2018 GMC Sierra 1500 with 6.2l and Max Trailer Tow package. This setup was perfect! Awesome daily driver and towed great.
January 2018, went camping in the desert (our usual haunt) with my BIL who had just purchased a bumper-pull TH and a Can Am X3 side-by-side. We were hooked! Ugh, why didn’t this happen before we bought the truck and trailer?
A few months ago we traded in the Forest River on a Grand Designs Momentum 25g and a Yamaha XYZ1000r. With 100 gallons of water and a 1600lb buggy we are probably pretty close to the GVWR of 11,500#’s.
The GMC tows the trailer really well. There’s no shortage of power except on steep grades, and then if I rev it out it’ll stay at 60MPH. With the integrated brake controller set at about 5 – 5.5 (out of 10) it stops pretty well, too. The problems however are two fold. 1. I know I’m beyond the safety limits of the TV’s towing/load/axle capacity. 2. On the Interstate last month I was passing a big rig and my trailer went into a fishtail. Boy, was that scary. But, I knew to grab the trailer brakes and press the Go pedal. It straightened right out. Still, I didn’t like it.
DW and I know we are going to end up with a 5th wheel garage model TH in a few years and we’d hoped the 1500 would get us through with our current trailer. But, that fishtail incident was a wake up call to take the hit and trade in the 1500 for a 3/4 or 1 ton sooner rather than later.
I know a diesel is going to tow much better than a gasser. But, what I really want to know is if the engine choice will affect the non-power related towing characteristics of a ¾ or 1 ton crew cab standard bed truck compared to my short bed ½ ton GMC? Towing stability is more important to me than power.
Also, I live close to work and my truck is my daily driver. We tow about once a month roughly 100 or so miles each way. In the Summer we tow into the mountains a few times and do one big trip into AZ, Nevada or Utah.
What are your experiences? Sell me on a truck that will best suit my needs for the next few years.
Thanks,
Chris
  • You live in California so mountains will be a fact of life if you want to go anywhere. To me a diesel is worth it for the relaxed towing experience, and even when I'm just commuting in it or taking a road trip with the family I think all that torque makes for a nicer truck compared to a gas version. My truck is in my sig and I really like it, but if you're buying one of the new crop of diesels I'd recommend the Duramax to avoid the CP3 pump in the Ram and Ford - it's not worth asking for that trouble when you have a good alternative that avoids it altogether. When I bought my truck the Cummins was the only option without the CP3.
  • "P" class tires and "ride quality" narrow rim width is my guess...no matter how good the WD is...
  • agesilaus wrote:
    Do you have a antisway load distributing hitch? If not that may take care of the fishtailing.
    I do. I'm using a Camco Eaz-Lift Trekker 1,200 Weight Distribution Hitch with Progressive Sway Control. I really like it. I just think I don't have enough truck to tow my trailer when the buggy is in it.
  • Kind of inline with agesilaus question, but was the sway incident on your way home? Was the nose light because you had used most of the water? I'm assuming the toys were in the very back so they were lightening the nose that much more.It may have been a load distribution issue.
  • Do you have a antisway load distributing hitch? If not that may take care of the fishtailing.
  • I'm looking very hard at the 2020 GMC 2500HD Gas. Will be a 6.6L with 401 hp and 460 ft/lb. And a payload of just under 4000 lbs. But not available until June (ish) and I won't be looking until next year anyway. I tow now with a 2015 Sierra 1500 max trailer, 5.3L.
    If I were to go diesel, I would pass by the 2500 and go 3500. It's not so bad with the 2020's, but 2019 and older you'll find you don't have much more payload with a 2500 diesel vs. what you have now. I'm at 2015 for payload and most of the 2500 diesels I've seen are much more than 2300 lbs. I'm comparing CC numbers.
    I don't tow as much as you are (8,200 lbs wet) and my truck is good enough for now.
    I've had a diesel in the past (01 2500 Duramax) and also had a short commute (~3.5km) and would end up parking the diesel in the winter and by a POS for a few months as the diesel never got to operating temps. I'm not looking to get back into a diesel anytime soon for that reason. I just don't work it hard enough 90% of the time.
    Outside of power, the biggest difference in the gas vs diesel will be the tranny. Again, I'm only talking the GMC here, but the diesel has a 10 speed version of the Allison (not actually made by Allison anymore) and the gas will be a 6 speed. And you will get more engine braking with a diesel.
    The 6.6 gas will not have the power of your 6.2L. That is a nice motor. But it will be better than the current 6.0L in the HD trucks.
