narcodog's avatar
narcodog
Explorer II
Apr 03, 2016
Not today
Not today but all week it seemed like. On Tuesday I decided to de-winterize the rig. I thought about two hours then onto the next project. Now when I flush I usually just fill the tank and go from there. This day I decided to you the city hook-up, I never use this for anything. I flushed the system, water coming from all faucets. Now time to fill the tank and sanitize, that's when the problem started. I filled the tank put the Clorox in and started to run it through the system. THe water in the bath was running shut the faucet off, turned on the kitchen water came through then stopped. What the devil is going on. I check all of the connections, no leaks. I hook the city water back up, no water. Okay, must be a bad faucet. I head to HD and pick one up, $124.00 and I need two adapters to connect the different size lines, both female 12/38 in. The sales person says here is what you need. Get home open the package, nope will not fit.Wed. I head out can't find what I need. Go back to HD another associate says this is what I need. He seemed like he know what he was talking about, we open the package and sure enough it part fits. I tell him I need two, he says there are two in the package. I get home and yup there are two adapters, freakin different sizes. The next day I head back to HD and the same guy says oh ya there are two different sizes, ok. He said you'll need brass, a little more costly,
no problem. I get home without looking at the package and **** wrong size. I turn around go back HD I find what I need by myself this time, problem solved, sort of. I turn on the pump no freakin water. I take the feed lines apart close the bypass valves and blow the lines backwards. Put everything back together, I have water. What an ordeal, I must say...
