jimh406's avatar
jimh406
Explorer III
Jun 17, 2016
Now that many of us have LED lights ... why 6Vs and solar?
I'm sure I'm underpowered compared to the rest of you at only 2 Group 24 12V batteries. I can't fit larger batteries, but I don't really seem to need them. I'm thinking about adding solar, but I generally only need a bit of generator power or driving to top my batteries off. I don't think that I'm that unusual with the advent of running LED lights.
So, back to the question, why do you have 6Vs and what do you use that uses that much 12V power or if you have both 6Vs and solar, so what do you do with all of that power?
  • I installed solar to avoid running my generator. I would use a inverter to run my direct TV system and 19" TV all that I wanted to, and could use 130 AH of battery power nightly.
    My 400 watt solar would make up that much power in 8 hours of sun.
    It also shades my roof.
    And your RV will consume 35 AH of power just to run the CO meter, propane leak detector and refrigerator for 1 day, about what 1 of the 120 watt solar panels will make in 1 day.
    So lights are only a fraction of the power consumed each day by the RV. In my case, the TV set used a lot of power. But for some, the satellite and wi-fi system will consume more power. Some use a internet connection for business while living in the RV full time. Some just enjoy playing on the computer, and use a small inverter and laptop.
    My favorite place for solar panels is this one. SunElec.com
    Have fun camping!
    Fred.
  • jimh425 wrote:
    but I generally only need a bit of generator power .....
    That there is why solar for me. I have not plugged in the charger or even hooked the charge cable up to the truck since putting the solar on top. Silent, reliable, and near zero maintenance.
  • Spend more time off the grid. The extra amp hours available with the 6V allows living off the grid without having to drive, plug in or run a genset to bring them back up. My previous battery setup was like yours, but as we spend more time stationary boondocking, the less that setup worked. Everyone's power needs are different so nothing wrong with your setup if it works for you.
