jodeb720
Mar 14, 2018Explorer
Guys,
Thanks so much for the tips.
I don't want to replace mine with anything plastic - I want it all aluminum.
That being said, my biggest complaint about towing is that the radiator really has a hard time shedding heat on hill climbs
I live in LA and when I head north to Yosemite, the climb out of LA (the "Grapevine" as it's called) usually causes the temps to rise up above 220 - 230. This causes my Trans temp to rise (and I have a 16 pass stacked plate trans cooler with an electric fan on it) as well.
If the OEM is a single, then a double should really make a big difference, if it's a double, then a third row will help.
In any case, I'm going to put an all aluminum unit in to replace my stock unit.
Thanks so much again!
Josh
Josh
44,066 PostsLatest Activity: May 15, 2026
