lawrosa
Mar 16, 2018Explorer
jodeb720 wrote:
Lawrosa,
That's an interesting point. I've put more rows in my old toyota back in the 80's and it ran much cooler.
I just assumed it would move the same volume across a greater surface area and radiate more heat - but what what you're saying makes some sense.
I already have a trans cooler that comes from the radiator to the trans cooler and returns to the transmission. I Don't know where the sensor is located (on the output of the trans or on the return to the trans), but generally on long pulls on hills, it climbs to the temp equal to or just below the water temperature - as it's on the rise, but once the water temp drop, it takes a long time for the trans temp to drop back down.
In any case, I need to replace the radiator because it's leaking at the engine oil connection to the plastic part of the tank.
Josh
You said you have a cooler with a fan on it? How big is it? Brand?
Maybe you have the cooler hooked up backwards.
Should go radiator, cooler, then back to trans... Maybe you picked the wrong line that you cut into..
Temp gauge is in the trans. I had the factory trans gauge istalled in my cluster... I have 1500 only...
44,066 PostsLatest Activity: May 15, 2026
