jaycoman89
Jun 10, 2020Explorer
Lynnmor wrote:jaycoman89 wrote:Lynnmor wrote:
You have a very bad connection somewhere in the 12 volt wiring. I would start by taking down any affected fixtures and checking connections. Also check ground connections near the battery and any frame grounds underneath.
Thanks! In your opinion does it sound like the poor connection is potentially to blame for each of these issues?
Yes, did you check any of those connections yet, or are you still taking a campground survey?
Just a weekend warrior but will be down this weekend to check it out. Seems to be a few different lines of thought floating around between wiring, battery and converter.
