toedtoes
Sep 13, 2014Explorer III
For no lights, check your converter.
For power, you may find you don't need more than what you have depending on how long you're out.
Like you, I only use battery power for lights and the water pump. Fridge is older and doesn't have 12v-only required parts. Lights are fluorescent (overhead) and LED (reading). I use battery operated LED puck lights for seeing inside cupboards, etc. My water pump is left on all the time, but only kicks in when a faucet is running.
For charging my cell phone, I use a 4-D battery pack (02 fan & battery). I have charged it for over a week without changing batteries. Laptop, I limit my use and use the house battery or an external power pack to charge. (portable power pack). I usually only charge once every 4 days due to limited use.
I have one 12v group 31 AGM battery for the house. A four-day trip without worrying about power will not even put a dent into the house battery. Although I haven't tried, I suspect with how my battery handles my needs, I could go 2 weeks without recharging. If I need more than that, I would go with a solar power setup rather than the generator - it would be more than sufficient to handle recharging needs without any added cost for fuel.
