hddecker
Sep 13, 2014Explorer
OnTheProwl wrote:
Thanks for the info. I have connected to shore power before and everything did work. I also looked for a switch to turn on for the battery power to work. Could not find such a switch, also called the PO and he said there was not such a switch.
OK, that's one thing that's eliminated, now check the fuses.
One other thing you could check before digging in is the ground. make sure that it is not corroded and that it has a good metal to metal contact point.
