tenbear
Sep 15, 2014Explorer
OnTheProwl wrote:tenbear wrote:
I suspect the converter is below the power panel. If you remove the panel that the open door, in the photo, is attached to you will probably see the converter.
Roger that! I'll take a look. I suspect unhooking the battery would be a good idea before removing the cover and poking around?
Probably not necessary unless you are poking around with a metal object like a screwdriver. You might want to remove any rings though.
Edit: On second thought, it would probably be a good idea to unplug the 120v plug, or at least switch the main circuit breaker off.
