rhagfo
Oct 18, 2019Explorer III
Grit dog wrote:bighatnohorse wrote:
Thanks. I had Walmart do mine today. Quick and easy. I have not inspected their work.
There were no oil leaks prior to today. I will slide under the truck tomorrow if it's not too freezing cold and take a look.
It’s ok. About a 1:1000 chance that the filter isn’t tightened. No need to slide under. If there’s not a puddle under it, yer good.
Most likely over tightened, if you can’t remove by hand it was over tightened. Once the gasket contacts 3/4 turn more, never a leak, can get off by hand. I also use old used oil on the gasket, used clean once about 50 years ago, destroyed that filter trying to remove it.
44,066 PostsLatest Activity: Apr 16, 2026
