budwich
Jul 29, 2014Explorer
go back to your "battery charger tester".... forget the hook up to the truck for now. Hook the charger ground to the tongue. Start connecting the charger "hot" to one wire at a time and write down the result. From there you will then know which wire on the trailer wiring does what. Then match it up to the "standard wiring" on your truck plug.
