westend
Jul 30, 2014Explorer
Sokniw wrote:Correct. Your yellow wire is shorted to ground. Have you pulled/replaced the existing tail light bulbs and inspected/cleaned the fixtures? Sometimes, corrosion or a parted connection in a lamp fixture will create a short to ground.
So if i test continuity and there is no short. than i will get no ohms right. 0.00 reading?
Update:::::
So i tested continuity from the ground and the wires here is what i get.
the brown and green wires read 06.0 and the yellow doesn't read anything.
These wiring shorts/opens can be time consuming to find. Even if you fix all the known problems, now, you will still be dealing with 50 yr. old wire and connections, later. IMO, it's easier to abandon the old stuff and install new wiring and establish good connections. I haven't bought a new four-wire connector kit in awhile but that last one was under $20, IIRC.
