Roadking284
Oct 01, 2015Explorer
Old camper wiring
Hello,
I am new to this site and hope this question is posted in the right area. I did a search and did not find anything close to my question.
1986 Prowler Lynx 26ft Travel trailer. Original problem: Battery not charging with shore power connected. I am 3rd owner and did get manuals from seller. No wiring diagrams. One sheet included stated check label on converter to see if battery charging option installed. Checked with mirror and flashlight no label anywhere.
Converter working fine with shore power all 12v systems work.
Upon inspecting wiring harness coming from inside camper to battery there are 3 wires connected to the positive post. I can understand two. One from converter red wire for battery charging, the other from battery to 12v fuse panel. Two wires are red one is white. One red wire was not connected and was capped.
I removed the wires from the positive post and with shore power connected the capped red has 13v all the time. I suspect the capped wire was charging all the time and boiling the battery dry and therefore someone dis-connected it. The white wire should go to the 12v fuse panel.
My question is what would the 3rd (2nd Red wire) go to? The tongue jack is manual only. The 12v fuse panel has 2 red wires attached to the positive feed. (thot one would be white).
The negative post on battery is black and is grounded to the frame.
Thanks
RK
Thanks
RK
