macdale4's avatar
macdale4
Older Lance Camper Dinette
I'm looking for a photo underneath the older Lance camper dinette. Some had a drawer pull like mechanism and I would like to see what it looked like so I can convert mine which has these mickey mouse aluminum brackets that don't work well.
  • I have a 95 880 with that table. I solved the problem by removing the table and storing it in the garage!
  • eimac99 wrote:
    There are no bearings - that's the problem The "slide" is just 2 long bent metal brackets on the bottom of the table with a square wooden piece on the pole. It's a very Mickey Mouse set up.
    You just described exactly what is on our 1996 Lance 500. No rollers or bearings. Ours slides OK, you just have to push/pull evenly with two hands. Yours may be tight and just need some redneck adjusting done to it.
  • There are no bearings - that's the problem The "slide" is just 2 long bent metal brackets on the bottom of the table with a square wooden piece on the pole. It's a very Mickey Mouse set up.
  • If the current slide sticks, a good cleaning and lubrication may solve the issue. Over time, the lubricant dries out and the bearings wear grit builds up. Just lubricating may not solve the problem.
  • I guess we need to clarify the situation. It is a 98 Lance 945 Legend with a U-shaped dinette. The table is on a single pole and slides out slightly so someone can sit in the back part of the dinette. We previously owned a similar TC and the slide on the table bottom was like a drawer slide and worked very smoothly. The current table slide sticks. We contacted Lance and they said they no longer make the slide we are looking for. We would like a picture of the "better" slide from some else's older Lance so we can redo the table.
  • What I have now is two aluminum strips that the lower table bracket slides back on forth in. What I'm looking for is a picture of the other system that Lance offered which was a two part slide mechanism "like" a drawer slide.
  • Not sure whether you want the drawer, or a better arrangement to hold up the table top, or both.
    I converted my two post table top to a Dream Dinette and just loved it.
