Cummins12V98
Jan 03, 2019Explorer III
Longer wheelbase for sure makes for a better ride. There is NO comparison between my 15 DRW's ride and my 01 2500 RAM 4x4 Sport basically the same as your truck.
I'm betting the hipster will compress more than the 01 when loaded.
Russ run 80 psi in the fronts ALL the time. Get the front aligned ASAP to 1/64-1/32 toe. The factory toe is 1/4 and this causes outside tire stepping, been there dun that on two Dually RAM's. Run the rears at 35 unless towing and 5psi above what your rear axle loaded weight compares to the load/inflation chart for your tires. 65 will be WAYYYY overkill for the rears towing for your RV.
Use ONLY Fleetguard, Mopar and Raycor filters.
I am sure you know most of this!!!
44,066 PostsLatest Activity: Apr 15, 2026
