NMDriver2
Jul 30, 2018Explorer
N2ZPY wrote:
Sounds to me like the battery is shot. Lights are a small load. By trying the jacks and slide you are putting a bigger amperage draw on the battery and it can't supply what is needed to run those loads.
Kevin
X2 you have volts but no amps is sounds like. On a meter the battery will show 12 or more volts but it is not providing amps enough to do any work. Take it to a WalMart or Autozone, etc and have them check it under load.
44,070 PostsLatest Activity: Aug 05, 2026
