JoeChiOhki
Aug 07, 2020Explorer II
BarryG20 wrote:
I am not Moomba but outback extreme does sell tanks. I bought mine local many years ago. As far as a blow down valve. They also sell those but they are not automatic. It is spring loaded, has a ring on the end of it that you can just pull on and it empties the air. I placed my valve on the bottom of the tank and while I don't really do it that often I can just reach up under the truck and pull it. What I do on a more regular basis is when I disconnect my air chuck from the quick connect is as I start to pull it apart I let a pretty fair amount of air out which also expels some moisture certainly not all of it but probably the majority. My tank is at least 15 years old and still hasn't rusted through yet from the inside and the outside still has plenty of original paint on it after living its life under the truck (though I do not live in a salt state)
My main concern was in winter operation with moisture in the system may cause damage to the valves and fittings, a manual valve will likely corrode on the tank before terribly long as road spray hits it, sadly :).
Moomba2002 wrote:
As Barry said I got all of my components from Extreme Outback Products talk with George he can give you more information than a brain can handle. They aren't inexpensive but the product and the customer service can't be beat.
Aye, I was eying their engine driven compressors they listed as well, though those I'm thinking are not 100% duty cycle units?
DWeikert wrote:
I went with the Airlift Wireless Air to avoid having to run air lines into the cab. I did have a failure of the controller/manifold but it was replaced painlessly under warranty and no issues since. One big advantage is it automatically maintains the pressure setting or the minimum 5 psi. Another advantage is I can walk around the vehicle with the controller in hand and adjust the air while watching the springs. I like to inflate the bags until the springs lift off the overloads then lower the pressure until they just engage. That seems to work best for keeping the side to side rocking at a minimum. They now have multiple wireless options.
My only thing about Wireless type things like that is its one more thing with batteries or electrical needs that's got a higher proneness towards failure. For major systems, the more basic and simplisticlly mechanical it is, the easier it will be for me to make emergency field repairs and maintain it :).
The convenience of being able to stand and remotely level the camper would be pretty cool, though.
