BarryG20
Jul 13, 2021Explorer
I am using an extremeair unit myself. It has been awesome so far and if it crapped out tomorrow I would not be upset. It has been underneath a truck for close to 20 years. And I do mean underneath the truck. On both trucks it sat /sits behind the cab underneath the bed on the pass side tucked up as high as possible between the frame rail and the bed side. I did fab up some protection panels for it out of some scrap aluminum diamond plate I had laying around. I originally put it on my 01 Ram then moved it over to my 17 Ram when I got a new truck. When I purchased it the Magnum was not out yet otherwise I would have bought that one. On my 01 I had quick connects on them front and rear of truck. On my 17 I just did one to the rear so I could easily inflate the trailer tires and the hose that does that will easily reach the front truck tires as well. Every once in a while I have to change the quick connect out for a new as they start to corrode and dont work so well.
I ran hose inside the frame rail where possible and any place it went through a hole or was rubbing on something I would zip tie some heater hose around it. I have yet to have a hose break/split whatever. Make sure and run heavy enough gauge wire to the comp for power and ground.
