JoeChiOhki
Aug 24, 2021Explorer II
adamis wrote:
My truck has two air compressors already, one for the airbags and the other for the Banks exhaust brakes. These work fine but I can't use them for airing up tires because they are two small for this function.
With my trip to Pismo Beach and airing down my tires to drive on the sand to get to a campsite, I have relied either using my pancake compressor or using a local fill-up station both which take over an hour to fill up (ten tires, truck plus trailer to 80 psi).
I've been looking into a much larger onboard air system, first looking at the ARB systems and other similar solutions. Eventually I stumbled upon the Extremeair Magnum system. I was quite impressed and after about a year of contemplating, finally pulled the trigger. The specs are:
Specs:
-1.5 HP Motor
-82 amps draw @ 100 psi
-Continuous Duty Rating @ 150 psi, 200 psi max pressure
-6 CFM @ 0 psi
-2.6 CFM @ 100 psi”
-Weight: 20 lbs.
-Dimensions: 16? long x 6? wide x 9.5? tall
I'm pretty happy with the specs and look forward to installing it on my truck this weekend. I won't remove the other two compressors immediately until I'm comfortable with how this system works. Eventually though, I want to tie everything into my new air system (I will have a four gallon air tank in my install).
Does anyone else have an onboard air system and what are your thoughts?
If I could figure out how and where I could add this guy:
https://www.extremeoutback.com/product/extremeflow-belt-drive-compressor-v-belt/
To my truck's engine, since the A/C pump and Alternator already share dual V-belts, I would do so in a heartbeat. It looks like it uses the same mounting point style as the A/C pump, but as much as I'd love the compressor, not having A/C is a nope :p
