mikeinaz wrote:
My current setup is 4500# dry and about 5100# loaded up. We dont pack a ton as we head out for 2-3 days at a time max. We also run w/ out water and fill up near where we camp. Hitch weight is 400#.
How do you know these are your weights? Did you weigh it or is this the mfg's figures or just your best guess? Typically, the tongue weight of any type of tt (htt) is around 12 to 15 percent of the actual weight of the trailer. Even at 5100 lbs, the tongue weight will be over 600 lbs.
The unit I am looking at is 26' TT and 5100# dry. About 5600# loaded up and a hitch weight of 500#.
Again.... use 12 to 15 percent for the tongue weight.
My TV is a 2013 Dodge Durango w/ the 5.7 Hemi, AWD and tow pkg, its rated to tow 7200# and the sticker in the door says vehicle cargo should not exceed 1200#. So figure 700# for 4 people and 2 dogs and then it leaves me just enough for DRY hitch weight but does not include the WDH weight or fuel if that is part of the calculation. I have read posts saying that w/ a WDH that figure is not 100% accurate and you can exceed it. I just dont want to white knuckle drive if I get this new unit.
You are already exceeding your Durango's payload rating
I currently tow the HTT fine, I live in AZ so any travel involves heading through the mountains and I do well on all but the steepest grades where I may be slowed to 55mph. So bottom line what do you think? Am I asking for trouble and am I exceeding the vehicle weight limit w/ this hitch weight? Thanks in advance for your thoughts.
Your Durango's Hemi has more than enough horse power to do the job, your concern should be on its payload rating. Exceeding the vehicle's weight limits is always inadvisable. I don't think anyone here can (or should) advise you otherwise.
Ron
