IdaD
Feb 05, 2021Explorer
I think in 2019 the Cummins went to a CP4 pump which is hot garbage. However I think they dropped it in 2021 and went back to a CP3 unit, which is what 2018 and earlier had. The 2017 you are looking at would be good to go and a huge step up from your F150.
I have a 2015 with 70,000+ miles on it and I had a water pump failure (which was later recalled) and a back-end NOX sensor failed which I replaced myself (I think the part was about $200 on Amazon). Otherwise it's been a solid truck and I plan to keep it a lot more years.
If you are buying used I would absolutely ignore the 2500 vs SRW 3500 distinction for this vintage Ram. Your used market is limited and they're the same truck from a capability standpoint, maybe with a $200 investment in Timbrens or airbags on the 2500 (and it wouldn't be necessary at all for your current trailer).
44,070 PostsLatest Activity: Aug 06, 2026
