Grit_dog
Feb 06, 2021Trailblazer
OP, that truck is one of the most reliable packages on the road. The only downside compared to the other 2 mfgs imo is the trans is behind the times for shift quality and programming/integration. That said it’s a solid bulletproof trans.
If it’s in great condition and verifiably well maintained then don’t hesitate if that’s the truck you want. And with those miles, it hasn’t needed any maintenance aside from a few oil and fuel filter changes. However if it hasn’t had diffs, t case and trans service, it’s time. So figure in that cost into initial maintenance. Brakes should be still very good. If they’re not, truck was driven by an idiot, which is a turnoff.
44,070 PostsLatest Activity: Aug 05, 2026
