JIMNLIN wrote:
JYI Ford markets the F350 SRW with a 10000 GVWR and a 11200 GVWR in the exact same truck.
The F350 SRW also come with three different RAWR from 6290/6730/7000 lbs.
Make sure it has the higher 11500 GVWR with the higher 7000 RAWR if your hauling heavy.
No way can the 10000 GVWR and the 11200 GVWR be the same truck! Those numbers are the result of careful engineering and testing...nothing to do with driver licensing guvvermint nonsense...
and besides that 10000 GVWR sticker alters the molecular structure of what appears to be identical parts found in the 11200 GVWR truck... making them prone to catas...castrat... a big scary collapse...
