2Macs
Aug 23, 2016Explorer
The grill you have in your pictures has a high pressure regulator and connectors for propane bottles. You cannot use this setup with your quick connect system which is low pressure. Go to your local RV dealer and you can get a low pressure hook up for your grill. The pressure regulator you get with a long hose (to keep the grill away from the RV) and low pressure quick connect will work fine. Keep the high pressure regulator and hose set up in case you want to use your grill away from your RV.
I had the same situation with my TT. We had a small grill that used the high pressure propane bottles that we purchase at Wal-Mart many years ago for $20. We purchased a new TT with an outdoor kitchen with the same gas connections you have. I purchased the conversion regulator and quick connect hose from my RV dealer for about $55 and the grill works both ways with no problems.
By the way, Wal-Mart still sells this table top grill today.
