Notakwanon's avatar
Notakwanon
Outfitter Apex electrical schematic??
Loading the truck for the Holiday weekend and found all the electrical inside the camper on the drivers side dead, so no lights, no water pump. Fuses checked and all good. Got to be a broken wire someplace but where? Is there a detailed electrical schematic out there somewhere for the Outfitter Apex? Thanks. Tom McCloud
  • Been on the road since Friday, so have not worked on finding the problem yet. Thanks for the schematic. I'll start troubleshooting on Tuesday. Lots of things still don't work, and the door lock mechanism broke on Sunday morning, so I had to crawl out a window. More things to fix. TM...
  • Never heard back from this post. Please let us know if you got the problem fixed and, if so, what was the problem?
  • It might be as simple as tightening the neutral wires on the feed panel. You can check easily with a meter to see if it is the hot feed to the devices, or if it is the neutral return that has failed.
    On volts, have one person hold one lead on the neutral bus, or use a jumper, and put the other end into the bottom of a socket. If you now show power, it's the neutral return that is off.
  • Have you checked the switches below the fridge? My 2011 Apex had three switches there. One was for the outside light, one for everything on the left, one for everything on the right.
