joerg68
May 28, 2018Nomad III
I am not familiar with the Rieco Titan system. Does their lift have individual motors for each corner? Or are they commonly driven? In the latter case the reson would be mechanical I guess.
If it is individual motors, one of them could be stuck/broken (bad) or just not get power (less bad). If it is just a broken wire, a loose connection, a blown fuse or a stuck relay it should be fairly easy to find and fix. Maybe run some wires directly to the motor and see if it moves. But only do that if you know what you are doing, though.
Googling the issue shows that apparently the actuators can and do fail, so you may have to replace parts...
