ezrydrs's avatar
ezrydrs
Oven pilot won't light
I'm not having much luck searching. 2011 Fun Finder 215WSK. Previous owner never used the stove or oven inside the TT (has outside kitchen). We tried to light the oven and can't get the pilot to light. There's no gas at the pilot tube. I unhooked the tube from the valve and there's no gas coming from the valve in the pilot position while holding in on the knob. All three stove burners light and work fine. If I heat the thermocouple in the oven I can light the burner with a lighter, so the gas is flowing there. When the oven reaches set temp, burner goes out like it should, but no pilot to relight the burner. Has there been an issue with these things?
It's a suburban model SRNA3SBSE.
I haven't removed the valve yet. Was hoping someone had some info.
Thanks
Matt
