BenK
Oct 12, 2020Explorer
Over loaded pickup
Wonder how often this occurs...think often https://fordauthority.com/2020/10/not-smart-ford-f-150-owner-exceeds-their-trucks-payload-capacity-by-a-touch/amp/
pitch wrote:
Our local gravel pit will not load a single wheel pick up,no matter the rating.
Show up with a single wheel 3500 and you will be shovel loading right next the 1500,s
rhagfo wrote:JRscooby wrote:
Overloaded? Likely, but a little for-thought in the order of loading could improve things a lot. Put that sheetrock on the floor of bed would lower COG a bunch. Then put lumber on top, long boards end even with tailgate. Then center the shorter boards over front of bed. This would move COG back up, but also forward to level truck out
:S
That would likely not change a thing!
