howardwheeler wrote:
I have a 2012 F 350 Powerstroke SRW.
I am under on the tire rating. Each is 3750 at 80 psi, which I run always. So I'll not sweat it since that puts the rear axle at 7500 lbs per the tires. I've been doing this for a year and a half with zero problems. No heat on the tires. I check them.
Must be one big 5er, should got a Dually!
While most will say you shouldn't exceed any rating, the tires on a SRW tends to set the axle rating. If you are safely with in the tire rating, then it is up to you.
